Haven't used my TT in years. I had loaned it to my son and recently found it in his stuff.
I have a GPS on my car and a Garmin. Hate both of them.
Wanted to use my old TT but not sure what my son has done to it but it doesn't work.
I decided to restore to original so downloaded Home and hooked it up went to restore and it will not restore. It indicates no restore point.
I know for sure I backed it up originally as I made a note in my files with the location and when I go to my old PC it is there under home/backups/go/backup01
Within this folder is a directory named storage and a file backup info.ini
Can someone explain why Home does not recognize this backup?
In reading the forum I saw where it indicated to follow this forum instructions for backing up and I assume restoring using windows explorer
https://www.tomtomforums.com/genera...4-how-backup-contents-your-unit-computer.html
This link no longer exists I suspect TomTom don't want us to backup manually but not sure why.
I have done the following; installed using windows explorer all the contents of the storage folder from the backup, connected the TT using Home and then asked to update. It then made a backup which I notice is under a folder "one" whereas the original was under a folder "GO". Why the change or does it not mean anything.
Navcore is now 7.903. Is this the latest that can be used on this TT?
