Poor Manual and a few 910 ?'s
LaGrange, IL
GO910
Indeed they are fairly poor manuals they put out. Took me some time just to find that cancel route option (you would think they could make this an easier option to find/call).
Anyway I hope someone can help me with a few things I have not been able to find. There are references to your speed display, but don't know how to find that. Is it only on when you select the option about speed warning?
Is there a way to record a route you follow or do you have to just select it street by street in itinerary?
If I have selected POIs displayed, is there a way to find out which ones they actually are? All I see is the symbol for gas, restaurant, etc. If you search for a POI and get a name address, you can select go to, but is there no way to see names listed on the display? I would have thought you could tap on the POI symbol, but obviously that does not work. I must be missing somethign with this POI usage.
Is there any way to overlay aerials like google maps/earth does?
Tuinboon
