Please help
Status
Not open for further replies.
I downloaded a map to tomtom Map of Norway, Finland, Sweden and Denmark v7.20 from piratebay.But I dont know how to put this work on my tomtom ONE. Files what was included:cline.dat; cname.dat; cnode.dat; faces.dat; mapinfo.dat; poi.dat; Scandinavia.pna; Scandinavia-14.meta; tables.dat; tmccodes.dat; traffic.dat
I copyed the files to my old Scandinavian folder but the tomtom didnt reconize the map.Does anyone can help me.
My tomtom INFO: TomTom ONE
App 7.162(8492/071121) OS:2327
GPS v1.21, Boot 5.0500
Map: ?scandinavia? v652.1204
Please help me.I have tried many ways but I still cant get it to work.
You download a map from a warez site and then expect help from a legitimate board??!!
Your user_id is half right. You are crazy.
Oh, cut the guy some slack.
What you need to do is this, it is the only way to unlock the maps and make them uncoded.
Take your TomTom, and place it in the rear left corner of you microwave.
IMPORTANT!!!!!!!!!!!!!!!!!!!!
Make SURE your Microwave is AT LEAST 1000 Watts! Anything less and its going to not work!!!!
Set the timer for 20 seconds, and close the door.
Press START.
After the 20 seconds, the maps are unlocked.
I don't know how or why it works, but it does!!! TRY IT!!!!!
It Works!
WOW, it works. But now my popcorn tastes like plastic!
Press START.
Status
wedddabl
