- Joined
- Mar 7, 2009
- Messages
- 6
i have used gps systems before for work but that is pretty much it. i don't do the updates of the maps nor the operating system... my company does that for me, i just know how to use them. i have no idea how big the maps are nor the operating system.
i am planning on getting a unit, not a very expensive one, i was in between the tomtom 130 s and the tomtom xl s but i have a few questions in regards to internal memory as well as sd card slots.
is it safer to buy a unit that has an sd card slot other then an unit that only has the internal memory in case the maps start getting bigger and bigger in size and they end up not fitting the units that only have the internal memory?
or will tomtom ALWAYS provide smaller size maps that will fit their units that don't have sd card slots?
i am afraid to purchase a unit without the sd card slot and then later the maps start getting bigger and bigger and i can't fit them into my unit. do you think this will ever happen?
other then my concern above i would like to have a unit that has the "text to speech" feature.
thank you all for your input.
