- Joined
- Dec 27, 2010
- Messages
- 2
Can anyone tell me how to remove languages and voices to free up space for a map update? Thanks!
Rich
Rich
Thanks. Any other suggestions for freeing up space?
True if using a Mac. In fact, the bin will have to be emptied first, then disabled through one of the couple of available methods when using a Mac. For some reason, Apple thinks it a good idea to keep LOCAL recycle bins in "external" devices like a TomTom, thumb drive, etc. Has caused more than one TT user to pull hair...Also you may want to disable recycle bin on the TT drive. This is more prone to cause insufficient space to update the maps and it will never be updated.
