Hi, can anyone please help. i have a tomtom 7150, just over 12 months old, i came to do some updates using "My Tomtom" but my laptop would not accept my device,I have never had this problem before and i have tried the following
re-installed the software, changed the USB port, changed the usb lead to device, re-set the device, restore factory settings on the device, tried to update using my sons laptop, but still cannot get either laptop to accept the TomTom.
If i go to the device manager on the laptop. i cannot see the tomtom in either network addaptors or USB mass storage devices, but i am getting power to the tomtom, because it is charging up... unfortunately TomTom web fleet will not speak to a meer mortal like me and will only have conversation with their distributors, unfortunately the company i purchased it off are drawing a blank because, yes you have guessed it, it is just out of guarantee
can any one out there help... thanks
Tony
Tony
