pin pointing
Hi everyone
I started a new job last week and when I eventually found it I thought I would pin point my location as my sense of direction is terrible. anyway when I used my sat nav the next day it navigated me a half of a mile away from where I set my pin point and of course I was lost. is there anyway of sorting this problem out or has anyone else experienced this thanks in advance.
im not sure about the version I just do map updates once a week. thanks for your quick reply
When you said that you pin-pointed your location just how did you pin point it?
Did you select it from the map or what?
On his 520 he can tap "Help Me" and then "Where am I" and the exact coordinates are locked in.
It is even easier for you.
Menu >> Search, select "Coordinates" and the current location is shown under the command line.
Robbert
