Pin codes
Pin codes?
Are you looking for bluetooth handsfree, data, or both? You need enable discovery on your phone, to attempt to pair the phone (initiate with the Tomtom). If it's compatible, the Tomtom will succeed in finding an pairing with the Sanyo.
Tomtom's are finicky with which phones it pairs with, if the pairing fails the Sanyo is likely not compatible.
sherra
