How does one enable/disable: Optional warning when exceeding recorded speed limit? I can't seem to find it.
Hi bandyshop,How does one enable/disable: Optional warning when exceeding recorded speed limit? I can't seem to find it.
Hi bandyshop,
You don't need tripmaster. That option is under 'display preferences' i believe;
main menu > preferences > display preferences > speed
I have a 910, and that is how to enable it.I haven't found it on the 910, that's why I set up Tripmaster for that.
Really? I wouldnt want to feel guilty having a little device tell me if I was speeding.There's no "display preferences" and I can't find that function. When you get a chance could you check where it is? I would like to use it.
I just want to know whether I'm going fast enough to get a ticket.
I know, I was just kidding. I think its a good feature. Hell, I think the roads would be a lot safer if everyone was reminded when they were speeding.
My bad, it's 'Status bar preferences';
Main menu > change preferences > status bar preferences > speed
