ONE XL Battery meter
Keller, TX
ONE LX
I can only tell the status of the battery when my TT does a route calculation. I tell it pick a destination and it does the map over view and shows how many sats are in view as well as the status of the battery. Is there any other way to view this screen with out having to plan a destination?:confused:
Just tap the signal bar area on the screen, and you will see the battery meter in the same place.
Tuinboon
