One wish. Improved visual warnings (speed cams)
<img src="/styles/default/custom/flags/ad.png" alt="Andorra" /> Andorra
Rider 2013
Hi again,
As I don't use helmet headsets connected to my GPS when riding my motorbike, I have no way to be "well warned" about the proximity of speed cams (my country is crowded of them). The only visible way is a tiny icon which is difficult to see.
When I am closing to the exit lane, a full display image appears on my TomTom Rider. It's easy to see, although you're not watching the screen.
My wish were to get a "high contrast flashing screen" which appears every time I were near of speed cam (or any kind of POI, as speed cam really is). With this, I could be able to be well visual warned.
Do you know if there is something like this?
Any developer would be interested on it?
Jordi (Barcelona)
The current versions (starting ~2011) of TomTom devices are designed such that you can't run 3rd party software on them. Only TomTom could add such a feature.
