One 3rd Edition problem
UK
TomTom One v1
Have a TT One 3rd Edition.......
Was told by Home s/w to update so did so....TT crashed and didn't update properly....now ttsystem in root is a 0 byte file and nothing will work...........If I try to run update from home it crashes out....HHHHEEEEEELLLLLPPPPP
Do you have a backup? Your device is an End of Life model so no further map updates.
Is there any content in your map folder (either UK_ROI or W_Europe or similar names)?
If so, there's at least some chance of resurrecting it.
I am afraid that there is no hope after all the built in memory card is corrupted and will not format so I shall have to give up......Thanks for all the help anyway....
Yippeee!!!!!!
Decided not to give up and used third party s/w to format the interbal SD card.....Ran Home and then added my maps folder......total success
BartG
