No WiFi connection
GO620
Unable to connect to wfi . Coannot find correct password
That WiFi password should be on your router box.
On the back of my SAGECOM router, supplied by my ISP, Bell Canada, is the Network name and Network password.
I have no idea what it is your way, but a phone call to your ISP should solve the problem.
Except for getting Live Traffic from your cell phone a WiFi connection for the 620 is not necessarily needed.
If you have MyDrive Connect installed on your PC and connect your 620 with a USB cable, MDC is only used as a "flow through" to use your PC's WiFi to update your 620.
