No Audio via Bluetooth
I just bought a bluetooth motorcycle helmet so I could hear my TomTom instructions while riding. Unfortunately when I paired my PDA (Mio P550) up the TomTom, the voice could no longer be heard via the PDA speaker or in the helmet. However the windows media player worked fine in the helmet.
Can anyone help with this issue?
Just a thought,
Is the volume control /settings okay in the TomTom application? You haven't clicked on the mute button by mistake.:)
As you know that the helmet to PDA connection is working then it can't be anything major wrong.
Cheers,
