No audio from iPod
Go300, One, Go920T
I just got my iPod cables direct from TomTom (I know, I paid too much but I can expense it). I hooked it up and the TomTom reads the iPod just fine and says its playing music, but I don't hear anything (both internal speaker and FW was tried).
Anyone have any ideas?
Its a 920T and iPod 30GB video (last year's model)
Tomtom cranked up full blast as is the radio and there is nothing.
The iPod is at least at half volume. I should have some sound but there is nothing at all.
Have you gone in and checked the various speaker-out settings. When I hooked up my car stuff, I had to tweak a few different settings or else some stuff playeed and others did not. I don't know ipod though.
I tried to switch from FM to internal and back. no luck.
FWIW I will play anything I load on the SD card just fine.
Tuinboon
