Hi there! First time post!
Just wanted to let everyone know about a problem I had with my TT1 v3.
I tried to use the "Latest Map Guarantee," but unfortunately, there is no warning that the map is absolutely colossal. Almost a full gig. So unless you delete the maps that came with the ONE, the new US map will never fit alongside the Guam map.
So what happened was, TTHome installed the Guam map, but not the US/Canada map. Then I started searching forums and found out about having to delete the original maps. Ok, fine. Did that, tried to restore, and suddenly that would not work. I also could not install the new map. Now I'm really freaking out, because not only do I not have my old maps, my new map doesn't work either.
Home kept failing to install the maps. So I tried the direct method. I closed out Home out of the tray and tried doing the transfer via Windows Explorer. NOW I got an I/O error saying, "Cannot copy file, path too deep." So this was why Home kept failing to install as well.
Come to find out, after some research, it wasn't a problem with the TomTom. It's a bug in WinXP SP2 in that somehow the USB2 port gets confused if you have to transfer very large files and you are connected through a USB hub. Apparently people who do a lot of file trading have this problem with their USB external HDs.
So I plugged the TT directly into the USB port on my laptop and wouldn't you know it, there was no problem updating to the new map once I deleted the old stuff by hand.
I know I've seen someone either on this forum or another with similar problems so I hope this solution helps.
