Newbie with a battery question
TomTom One 3rd
I have the TomTom One 3rd edition.
I do love it and can not imagine life without it anymore.
The battery is all but dead however...if not totally dead.
I am fairly handy and want to change it out.
The process sounds simple enough.
Unscrew the 4 torx screws, take out and unplug the old battery, plug in the new battery, put the back on and enjoy.
I am thinking that is all that needs to be done based on other postings.
If this is not correct for my TomTom, can somebody tell me what the correct process is?
Also..I am not eager to go into my machine until I have the replacement battery in hand. What is the replacement that I need and where is a good place to get it?
Thanks all
Knot
