Hello,
I have a broken TT Go 730. Having paid alot of money for it 18months ago i really would like to try and fix it and hoping someone can help.
SYMPTONS:
It initially started getting slower and slower to load or do anything and it has finally just stopped! When i plug it into my computer i can hear the usb "dung dung" connect but i can not see anything under "my computer" on the pc. ( I can if i put an SD card into it). This is a far as it will go. Having read many other forums and have run out of options. I have tried hard resets.etc with no luck. I have not backed anything up historically so i am stuffed on that front. Don't get me wrong i have not idea what is wrong with it, but i "feel" as if the firmware is corrupt on the internal memory. Is there anyway i can load up a firmware from an SD card. Somehow run a slef extracting file to the memory? I would be happy enough to have it working of an SD card. I just want the bloody thing to work!!! Any advice or directions would be greatly appreciated!!
Scott
SYMPTONS:
Scott
