Need to identify battery for 30 Series
I need some help in identifying a replacement battery for my 30 Series TomTom One. This is NOT the XL version.
None of the usual battery suppliers I have found on-line seem to mention this model. I know I could take it apart and have a look, but this is quite tricky with this unit (no external screws) and I don't want to do that unless I know I can get the battery first.
Thanks in anticipation
dch222
Thanks but I have already done that and it gives me three answers, 30 Series, 125 and 130. I already know mine is 30 series.
Take the label off the base and you should locate the two torx screws securing the device together - Mike
Thanks for the replies but it looks as though I will have to bite the bullet and take it apart and have a look before I can buy the battery.
The 30 series doesn't have screws accessable from outside - you have to prise the screen off first.
Found a video of how to to do it here:-
YouTube - ‪NewPower99DotCom???‬‏.
Peter2471
