Depends. Which of the features on your 730 do you treasure the most? Features such as FM modulator and aux audio out haven't been offered for quite a long time. No *.itn itineraries, either. Let us know what you use the most.One last question.
Being the unit is approximately 9 years old what would would be a good replacement to my old GO730?
Thanks Again
ok it said it is a via 1500/1505The model number you show is not a correct one. See here to help identify:
http://us.support.tomtom.com/app/answers/detail/a_id/9521/c/2355
Start 25 / VIA 1505 - 4GB TTS* (MyDrive)The model number you show is not a correct one. See here to help identify:
thats what the thing brought upStart 25 / VIA 1505 - 4GB TTS* (MyDrive)
yes were and yeah it doesn't matter what we try it just dosen't stay chargethats what the thing brought up
and the computer tooyes were and yeah it doesn't matter what we try it just dosen't stay charge
is there a way to get a new battery? something said to factory reset but not sure how to do that with this one
ok thanks .. thinking it is a bad battery where do we get a new one for it?Factory reset probably wouldn't help. (Settings-->Restore to factory defaults). You might try a drum reset on the unit by holding the power button about 20 seconds till you hear the drum sounds. May not help but won't hurt.
See below:
