My TomTom Go 730 Does Not Switch On
My TomTom Go 730 is just under 4 months old. I used this during my summer holliday without any problem. Last time used: a couple of weeks ago.
After using this a couple of week ago I tried to switch it on yesterday but it would not wake up. I then let it charge for overnight and tried to switch it again again this morning but in vain. No activity on the screen which remains black (i.e. no power)
I have tried the following methods so far:
1. pressed power on button for lesss than 5seconds before releasing
2. pressed power on button for 10-20 seconds before releasing
3. pressed reset button for 20 seconds, released it then pressed the power on button as mentioned on 1 and 2 above
4. pressed reset and power buttons simultaneously for 10-15 seconds, and released the buttonsit then pressed the power on button as mentioned on 1 and 2 above
Just a note that green light does appear during charging through the USB).
I am hoping to get a solution to this here or else I will contact TomTom support and try to get it replaced. P.S. Anyone had an experience with repair/replacement from TomTom? I am in scotland, Uk.
If it is under warranty, just call UK support and let them send you the appropriate packaging for a RMA.
Peter2471
