Hello,
My brother has a GO DISCOVER 6" unit and has been trying to find a mount for it, as the one that came with the unit cannot hold the unit at the required position (it slowly tilts downwards; it seems the little sphere/ball is loose). He bought a new one (9UUB.001.40 I think) and unfortunatelly the same happened again after some time.
He would like to buy a new one with a ball tightening mechanism this time, like the 9UYB.001.04 but this is only available for 7" GO DISCOVER.
Could anyone advise a solution the tilting problem or a new mount with a tightening screw?
Thank you!
Thank you!
