More than 1 route to plan
Go Classic
How do I plan f.e. 3 routes?
So, I start on place A, via B and to C.
Tom Tom Go Classic
Let me be clear. Are you trying to plan a route that has multiple stops? That is just one route with multiple waypoints.
There are two models of GO Classic, one very old and one relatively new.
The really old GO Classic has the tiny 3.5" display. Serial number that starts with the characters "B1". The newer one looks like this (below) and probably has a 5" screen. Just want to be sure which one you have first since the answer would be very different!
martinvans
