I go into my quick menu, and select mark location of map error when I want to mark a location.
I then go into the main menu, and select map corrections. It tells me that I've marked 1 location and if i would like to review and change it now. I select Yes.
Instead of showing me the location that I marked, which it used to do a long time ago, it shows me a screen where the left upper 1/4 of the screen is blue, like the color they use for water on the map, and the 3/4 rest of the screen is green, like the color they use for grass. When I select handle now, and select any option, such as unblock street, it uses my current location, instead of the location I marked.
The above paragraph is my issue. I used to be able to mark locations and have it show up properly, but I'm not sure what happened.
The issue has come up whether I used 8.351 or 8.395, an 840 map or an 850 map.
