Manual Entry of Phone Numbers
Is there a way to manually enter phone numbers into the 920T phone book? My Samsung Blackjack won't transfer them.
Yes you can.
Locate the contacts folder in ur unit's directory.
Go in there and manually create a text document called 'contacts'
Each line will consists of the follow information:
"Bob","555-5545","DEFAULT"
Type it exactly how I did with the quotations.
Enter as many as u want.
Tuinboon
