Hi
I hv a 950 live could someone advise me when you start satnav and live starts even before setting route info comes up incedents --- type if I remember what is it referring to?????
then bar clears with no info until route put in.
Advise to 950 live users
when updating to 9.041, please remember if you don't accept sharing info your live will turn off, and I went into my live account and this time pushed yes it did not work rang tech support had to reset back to factory reset.
When you make changes also in some item for example your details that share message will appear you must push yes
Hope that helps someone else
Tony Miller
Tony Miller
