saw in this forum that the iPod connect cable doesn't allow for charging iPod so that seems to be a bit of a problem but I was wondering how it connects to the GO 720 ... was concerned that it used the USB connector in which case the GPS wouldn't be charging either ... can someone enlighten me since I don't have access to the cable
Thanks!
Dave[/QUOTE
The kit from TomTom includes 2 cables. One uses the iPod dock connection (not the headphone jack) and connects to one of the round ports on the bottom of the 720. The other is a standard (3.5mm I think) audio cable that connects to the audio out jack (also on the bottom of the 720, right next to the iPod port). This can be plugged into an aux in jack on your car stereo, if you have one, allowing you to feed the audio to your stereo without using the FM transmitter. Better sound quality that way. The USB port is still available and accessible for powering the 720.
Also, the kit says "TomTom Go 510-710-910" on it, but works fine for the 720. I think there've been some questions if this is the right kit for the 720 - it is. Works very well for me, but I do wish it powered the iPod.
Hope this helps.
