ipod cable - can I use any 3.5 to 3.5 cable?
London, Ontario
GO 720
I purchased a 3.5mm to 3.5mm cable at Source by Circuit City (Canada). When I connect my GO 720 to my ipod nano, nothing happens. It stays on the "Please connect" screen indefinitely.
Do I need to have a special cable?
Thanks,
Thanks,
The 3.5mm plug on the TT720 is for output not input. you need a special cable that plugs into next to the 3.5mm plug to connect the ipod.
http://www.tomtom.com/products/accessories/index.php
scroll down about half way and look for the accessory called "iPod Connect Cable & Audio Cable"
That's the one you need Doug.
Reido
