Hi all,
My TT is playing dirty games with me.
Last time whne I tried to do an update the message I've got from TT Home was: not enough space to complete the update.
OK, I said: I went to My computer - double click on removable disk and surprise: FREE SPACE: 0 bytes, USED SPACE: 0 bytes.
Then I went to Folder Options and checked "show hidden files" - NOTHING showed up.
I've tried to format the disk: it doesn't even start
Then I've tried a disk error check: again no luck
When I start it the blinking red cross shows up on the screen.
I am using WIN XP SP2.
I don't know....I fell like I wanna smash the little guy.
But I hope that somebody will give me the right answer.
Anyway, thanks on advance for any useful answer (even if that one would be throw it away).
Sebastian
Sebastian
