This just happened a couple of days ago after I updated My TomTom second edition.
The update may not be related, but I suppose its possible.
I can't turn on the unit unless it's plugged into the charger (or computer)
But once it's turned on it stays on when unplugged and the batteries show fully charged.
The battery level then discharges at the normal rate and lasts about 2 hours.
I can turn it off with no problems, but if I turn it back on i need to temporarily plug it in to the car charger to fire it up.
Can't figure out what is happening. Other than that it works great.
