Hi,
I did some searches but here, but I was unable to find anything helpful, probably my fault. My apologies if this has already been answered somewhere.
I recently bought a GO 730T on ebay and it is missing the TMC antenna and a remote control, so I looked around on ebay and found a load of Tom Tom antennas, secondhand, for sale. I found out that some use a small USB connector which I believe is not compatible to my 730, and some use a small stereo jack with 3 connections on it, this appears to be the type I need, but I was wondering if there is more than one type? Can anyone confirm or deny this please? e.g. can I buy any of the ones with the correct plug? There is even a stick version that looks really attractive.....
Also, a friend of mine in the UK has a remote control from a TTGO 700 from 2006 that he does not require anymore, and as my 730 does not have one, I was wondering if it is also compatible with my 730? It looks slightly different I am told. (by the way, I live in Germany and I don't want him to send it if it doesn't work together with the 730T....)
Another question, just for fun :thumb:, can I buy the "Truck" maps for my 730? I cannot find anything about them on Tom Tom's web sites.....though the 730 Truck versions go for much bigger money than I paid for mine so expect that they are very expensive....
I am sure that the questions are pretty simple for you Guys, but for me they are not......
Many thanks and have a great day.
Regards
Andy
Regards
Andy
