Hello Ladies and Gentlmen,
If possible I would like to ask for some technical help, with regards to installing a TomTom map onto my Erisin 966 all in one DVD, digital TV, radio and navigation system. I have used my TomTom one for many years and have learned to trust the maps and guidence, and would like to continue using the TomTom software.
Right here goes, please bear in mind I know pretty much nothing when it comes to GPS systems.
Recently I bought my new system for my car, I was excited when I got it out of the box and installed it. The manufacture who makes the sysem supplied a SD card with i-GO 8 installed, which to my horror when I contacted i-GO with regards to updating the map I was told the map was counterfeit and they would not supply me with any more support, so I am now trying to find a compatible TomTom map to use on the system.
My system requirements are as follows :-
Operating system - Windows CE 6.0
CPU - SiRFatlas IV
http://www.ebay.co.uk/itm/Erisin-ES966GB-Car-DVD-Player-GPS-DVB-T-Bluetooth-iPod-/120744682500
Ubove is the link to eBay, which will take you to the complete spec of the GPS system and the spec of the machine.
Since performing my own research into trying to locate a sutable map for machine, I have only managed to hit a solid brick wall, the i-GO map which is installed on the SD card in my machine, is saved as a exe file, and runs without a problem, however the TomTom map I tried from my TomTom one would not run as it is a itn file and the system could not open the files.
Has anyone experienced a problem like this and managed to find a solution, or does someone know of a TomTom map that would be fully compatible, or does someone know of a way to make a itn file executable other than changing the file path.
Any help will be greatly recieved.
CPU - SiRFatlas IV
