I need help - wiped memory card on TT ONE
tomtom one new edition
Hi there people ive a problem ive an tto new adition the prob is that i wiped the memory card and the read only file aswell is there any way i can fix this as i cant get ay thing to work. please help
First question has to be did you ever make a backup of the TomTom before this?
Or did you ever buy a new map and download it?
If you did either of the above we can get you back up and running completely, but if you didn't, then all we can do is replace all the software and voices etc. but NOT your original map.
I'm afraid if we cannot find your original map saved or backed up anywhere, then you'll have to buy a new one.
Do you have a copy of TomTom "Home" on your PC?
If you do, connect the ONE to it and see what it offer you.
If not, get it here http://www.tomtom.com/services/service.php?id=16&tab=87
(P.S. I've edited your topic title to give it some more detail)
