For whatever reason, I just can't see how using a remote would be easier than tapping on a screen directly. I understand it's great for larger vehicles where the device would be further away, but is the remote really THAT simple to use that people love these things so much? I've been thinking on buying one but can't find any reasons to. I drive a Honda Civic, so the device is pretty close to me. So reach is not an issue.
The remotes seem expensive for as simple dinky as they look. How does it work? Do you navigate around the menus with the remote by pushing, for example "right" "right" "down" to get to an option? Is it the same for typing in an address? Just move the box/curser letter by letter?
I could see maybe this would be cool if I mounted it some way to my steering wheel which would be very easy. Is $50-$60 US dollar worth it for the remote? I've seen where others here have said they will NEVER turn back after using the remote, it's that good.
Please enlighten me.
