Hi everyone,
I just got my GO730 and opened it. I used to use the ONEXL so am used to simply clipping the GPS onto the mount and then onto the windshield.
When I opened the box I saw this clip and got kindof confused - I looked at it and at the back of the GPS and I'm thinking there is no way to clip this GPS onto the mount!? The tomtom website shows that you just push it on and it should clip, but that looks like its a different version GPS. I checked and I have the right mount for the GO730 - but i'm just confused as to how to put the GPS and the mount together! Can ANYONE help me!? I tried looking for youtube videos or pictures but have found nothing! The back of the GPS looks like there is nothing for the mount to clip onto!!
Thanks!
Thanks!
