How to decide replacement battery for TomTom One V3
Hi All,
I have a Tom Tom One 3rd Edition Version 8.010. The battery of the device does not charge beyond a minimum level. I tried to charge after a restart but that did not help. I am looking to replace the battery.
My device currently uses a Maxell 653443 1100mAh capacity battery. I could not find an exact match and the replacement batteries available on eBay are of 1450mAh capacity. Can anybody advise if a battery with higher capacity will work fine?
thanks.
Yadgar.
BartG
