If you find that there is not enough space on your device to install any further updates, you will need to purchase a larger SD Card. I recommend that you purchase a 2GB SD card with a minimum read/write speed of 10mb/s or higher.
If you have a TomTom GO x20 or x30 device (e.g. 520, 530) you can purchase an SDHC card up to 4GB.
If you have a TomTom GO x40 or x50 device (e.g. 540, 550) you can purchase a Micro SD Card up to 32GB.
All other devices will only be able to take up to 2GB.
Please see TomTom, portable GPS car navigation systems - Support home - Select your product for more details of expansion options for your device.
Some instructions will depend on whether you use a PC or Mac, and for these we have the PC instructions and first and the Mac instructions just after that so please follow the ones for your own system.
Once you have purchased the SD card, please do the following:-
STEP 1 - Create a Backup Folder
- Connect your TomTom device to your computer and switch it on
- On a PC, create a new folder on your desktop and call it 'Backup'
- On a Mac, create a folder on the desktop and call it 'Backup'
STEP 2 - Copy the contents of your TomTom device to your Backup Folder
On a PC:
- Open 'My Computer', you will see the TomTom device as a removable storage device, e.g. TomTom (E
, double left click into it
- Click on Edit -> Select All, and then click on 'Edit -> Copy'
- Go to your Backup folder on your desktop that you have created, double left click into it and click on 'Edit -> Paste'
On a Mac:
- Yyou will see the TomTom device on the Desktop, double click into it
- Select and copy all of the contents of the TomTom device
- Go to your backup Folder that you have created and double click into it
- Paste all the files into the backup folder
- Once complete, switch your TomTom device off
STEP 3 - Format the New Card
- Insert the new Blank SD card that you have bought into your TomTom device
- Switch your unit back on.
On a PC:
- Go to 'My Computer', you will see the TomTom device as a removable disk
- Right click on the Removable disk and choose 'Format'
- Make sure FAT or Fat 32 is selected.
- Proceed with Formatting the SD card
On a Mac:
To format the card you need to use Disk Utility
The application can be found under Applications > Utilities > Disk Utility
Click on Erase from the top middle bar then select the volume format you want to use
For SD cards to be recognized by the TomTom device, select MS-DOS File System
STEP 4 - Restore the Folders to the TomTom device
- Go to your backup folder on your desktop
- Select and copy all of the Folders but NOT the loose files
- On a PC, go to 'My Computer' and double click into the TomTom device drive
- On a Mac, double click into the TomTom drive on your desktop
- Paste all of the folders into the device (this can take a while, e.g. anything up to 1 hour to complete depending on the device)
- Turn the device off (with the on/off switch) and disconnect it from the computer
- Switch the TomTom device back on
STEP 5 - Install the latest application via TomTom HOME onto your device:
- Install the latest software update via TomTom HOME (see: TomTom, portable GPS car navigation systems - Support home - Select your product)
- Once the update has been installed, disconnect your device by clicking on 'Device -> Disconnect Device' in TomTom HOME
- Turn the device back on, the update will then install on the device
Your TomTom device should now be working with the new SD card.
Vorlon
On a PC:
On a Mac:
On a PC:
On a Mac:
Vorlon
