How Do I reenter My Info.....
Puerto Rico
TT One 3rd Edition
OK all,
Is there a way I can Start All over again on the
"TomTom One 3rd Edition"?
I entered the color schemes I desired to see, Day /Nite, the Voice I wanted to Hear, etc. etc., but the Location of the "Home" got entered incorrectly.
It says that I live on 19th. :eek: :confused: street, where it should actually be 20th....
I've pressed the "Reset" button, but all that did was just clear the Actual time of the unit, I think ???
Why not do it the easy and accurate way. an address probably won't be that accurate.
while sitting in your driveway or in front of your home, tap the screen, select "change preferences" ...on the next screen right arrow...then "change home location"...again right arrow and select "my location"
this will mark your exact position to return to.
Reply 2 "flyer1024;43105
Thanks flyer1024, I'll give that a try ;)
rose
