How do I fix my home location?
TomTom One 3rd Ed.
My Tomtom One Third Ed. was setup with my correct home address. However, the unit thinks that my next door neighbor's house is my house. He is about 800 feet down the road. Is there a way to override this?
Yes there is. I had to do this with mine as well.
Walk out to the front of your house (drive way entrance) and turn on your TomTom. Then... Tap
  • "Change preferences" <right arrow> <right arrow>
  • "Change Home location" <right arrow>
  • to "My location".
This way it uses your actual position via satellite computation instead of dividing up addresses in a neighborhood.
This is probably a pretty common problem. Mods might want to make this a sticky...it was a very good answer to the question.
Reido
