- Joined
- May 5, 2008
- Messages
- 5
I recently purchased a in dash dvd-tv-raido-gps unit for my car.It came with a sd card with a demo version gps from a company other then tomtom.When i asked the seller how i could get tomtom software onto the sd card i got this response.......
The trial map is to show that the GPS System is working perfectly and we send you a free 2 GB SD card with the trial map. If you want to upgrade from the trial map, you need to acquire a full version from any GPS software - Route 66 and TomTom are two types of maps that work very well and come at good prices. Usually GPS systems come with trial maps and not the full version.
Could anyone post a link to where i can purchase what i need? The pic is of the navi slot.
