help
New Hampshire
ONE
i was planning on taking my one on a trip fri but i lost my mount...or shall i say the kids lost my mount, anyway anyone know if any stores carry mounts for these?
Lots of online places have various mounts, including Ebay, but you might not get it in time.
I've seen mounts in Radio Shack, Best Buy, and Circuit city....you might want to try those retail stores.
I've actually seen TT accessories at Circuit City but be aware there is no price break compared to estores. You might also try Best Buy - I just don't remember what they had. Basically, any retailer that carries TT should have accessories. If you lost your charger/adapter, the car plug in for my wifes Motorola RAZR works fine with the TT. Don't know if I just happened to get lucky with that one but it makes sense that any any of them with the mini usb plug should do the job if you can't find the actual TT adapters.
Good luck.
druidude
