Need help with fixing two 910s that will not charge while in cradle.
I have two 910's with exact same issue - the cradles will not charge the units.
Symptoms:
The green light is on, but unless some wiggling is done, the battery indicator in the route overview does not say "charging" leading the unit to eventually to discharge and die. The charging will often stop even after wiggling was done.
I have cleaned the contacts on both units and all cradles I've tested this with. It does not look like a surface contact damage.
I have replaced batteries on both units, but the issue persists. (pre-battery exchange, one unit was completely drained and would not power on, and the other was getting there)
I have cleaned contacts on all cradles and units -
A few observations:
* The green light on the top of the unit does not seem to indicate charging - but it does seem to say that
* The unit will not turn on if the battery is not charged, and if the charging is not happening, eventually it will shut down due to battery drain
I am wondering if this is a charging circuit issue - maybe the current is sufficient for the green LED but not enough for charging?
Any suggestions would be appreciated as it seems a waste to loose two of these units. for something this silly.
Symptoms:
A few observations:
