Help please
Can anyone suggest a remedy for restoring English display to a Tom Tom 720 please? All was fine until I did a back up in Home after which all on screen action buttons and instructions are now in German! The map & street names together with spoken directions are still in English. Although it is still possible to use postcode searchfor travelling the fault is rather limiting. I have carried out a restore twice to no avail.
You'll be flying a little blind on this one...
"Change Preferences" is the picture of the blue wrench. Select that.
Keep hitting the blue arrow (7 times?) until you see the icon in the upper left corner that shows the 3 flags. That's the one for "Change Language"
Take your pick of languages from there. I didn't pay attention to your IP address before I started typing, so you need to decide whether English UK or English US is correct for you.
distractiblemerch
