I just got a TomTom One and so far love it. I'm trying to import my waypoints from my old Garmin, which is a gdb file, and am having trouble.
I've converted it to an ov2 file using POIEdit, which worked well. But I can't figure out how to place the file on my Garmin itself. I've copied it to My Documents\TomTom\HOME\Download\poi, then in the TomTom utility clicked Items on My Computer --> Points of Interest, but my file isn't showing up.
I don't think the file is bad since the same result happened for the online POI converter utility.
Am I missing something? Is there some other way to do this?
