Help getting 7.15 maps
The device guarantee leads me to download the new maps. But then when I'm up to the download, says I do not have enough free space. Am I doing something wrong?
You will probably have to copy/move files from the device to a backup folder on your computer. Use Explorer but make sure that it shows ALL FILE EXTENSIONS including hidden, system and read-only files. Then drag/drop them to your computer.
Then erase the files in that map folder on the device and try again. I thought TT-HOME offered me the option the other day of erasing files from device to make room for the update.
Or I guess you could purchase an SD card that has room for the updates.
