Hello I am new here so if this has already been covered I am sorry
I bought a new 2gb card with new maps on it , but my tom tom will not accept it even though I have reset it , any help would be most welcome
I don't want to give you incorrect information about how exactly to handle things with the card and model. Send a pm to mikealder, a member (also from the UK) whome I sure will be able to advise .
If this is a preloaded card containing just a map you will need to add the application files as currently the card will only contain a map folder.
I can detail how to do this if required, for a start though make a full copy of both the old working card and the new card to two seperate folders on your PC - Mike
I have made a copy of the old card , the new one will not let me copy without errors when copying the video files , but I would like to know how to put files and which ones on to the new card
