Hi all
Can you help?
I purchased a 750 go live march last year and sometime after that an update enabled my device to auto turn on with ignition but after update on 19/02/2012 that has now stopped and tomtom are unable to tell me why.
Also after update I now have the remaining time to destination showing in status bar which I did not have before and do not want as I am capable to work that out from the present time and estimated time of arrival, there is nothing in status bar menu to enable to turn remainig time off.
One final thing I do not use tomtom cameras but do have live sevices and wish to turn off the flashing red box on left of status bar if i break the speed limit, i know how to turn of the audible warning but not the flashing box, tomtom said if i uninstall tomtom cameras it will stop but as i said i dont have them installed as i use a third party.
Any Ideas???
Mick
Can you help?
Any Ideas???
Mick
