Help! 720 stuck in reset loop
When I restore my old mapsettings.cfg file to my new map folder it causes my 720 to go into a continuous reset loop. I've restored it many times before after updating the map but this problem has never occured. When I removed the file the unit works normally again.
Anyone have any ideas?
Yes....the newest application has caused issues with copying over the mapsettings.cfg file.
Do this:
Connect your unit and start Home. In Home, start the emulator (Operate my unit). Manage Favorites. Select a favorite and delete it. Save. Disconnect the unit properly from the computer. (Home-->Device disconnect).
Restart the unit. Should be ok.
