GPS QuickFix Problem.
Kings Lynn, Norfolk
TomTom One v3
For the past two weeks I have been trying to update my Tomtom One v3 with the latest GPS Quick Fix but I keep getting the error, Cannot create this file: G:\ephem\lto.dat I sometimes get the message pasted below.
I have tried going into Manage my device in Tomtom Home and removing the GPS items, which it then states that it has done. I have used the windows explororer to go into the Tomtom ephem directory and there is a file there called lto.dat but no matter what I try it will not delete, when I click on delete it states that it has been deleted but if I then click on the directory again it is still there, if I try to view it with Notepad it says the file or directory is corrupt or damaged.
Please can anyone help me with this or point me in the right direction.
Regards. Colin.
Here is the error message that I get.
ERROR: HomeBase/IO: Error writing file: G:\ephem\ee_meta.txt
@ .\portable\cfile.cpp(1947)
0000045D
in .\portable\cfile.cpp:1947
Stack:
0. chrome://tthome/content/ui/bindings/commit.js:82
error(textOrException);
1. chrome://tthome/content/ui/bindings/ttwizard.xml:1061
this._commitFailed(i, commitPage);
2. chrome://tthome/content/logic/util.js:79
return func.apply(obj, arguments);
3. chrome://tthome/content/logic/dllUtils.js:77
this._errorCallback(e);
4. chrome://tthome/content/logic/dllUtils.js:69
this._errorFatal(error);
Besides using Explorer to delete the ephem folder on the unit, go here:
c:\documents and settings\yourname\my documents\TomTom\Home\Downloads\Complete\ephemeris\ and delete any sub folders found there.
Then connect to Home, see if a new gpsquickfix is offered and, if so, install. See if it works ok now.
Just did as you said, when I first switch on the TomTom I get the error message below.
ERROR: HomeBase/IO: Error writing file: G:\tthome.bif
Stack:
0. chrome://tthome/content/logic/login.js:306
} catch (e) { error(e); }
1. chrome://tthome/content/logic/login.js:298
this._notifyChange();
2. chrome://tthome/content/logic/login.js:112
me._setTo(username, password);
3. function validateNext chrome://tthome/content/logic/login.js:335
validationSuccessful();
4. chrome://tthome/content/logic/loginDeviceRel.js:89
acceptCallback();
5. chrome://tthome/content/logic/comm.js:442
this.successCallback(this.resultXML);
6. chrome://tthome/content/logic/comm.js:430
this._doneCallbacks();
7. chrome://tthome/content/logic/comm.js:277
this.request.onload = function() { me._done(true); }
I then click on OK to get rid of this message, Home then scans the web for GPSFix and says there is one available, I click on install, it says downloading and then comes up with this error.
ERROR: DesktopLib/InstallToDevice/Install/Single/DestinationFileDoesNotExist: Cannot create this file: G:\ephem\lto.dat
@ .\framework\InstallToDeviceThread.cpp(1423)
Last Error is 0000045D Item metadata is <HOME2 version="2.8">
<ephemeris idnum="10001" idurl="http://num1.id.tomtom.com/10001" idstr="Ephemeris" version="1304784316">
<title lang="en-GB" mimetype="text/plain">QuickGPSfix</title>
<description lang="en-GB" mimetype="text/plain">With updated QuickGPSfix data your TomTom device can find its position much faster, especially in densely populated areas and possibly even indoors.
QuickGPSfix data contains information about where the GPS satellites are going to be for the next 7 days. To get the fastest possible GPS fix, make sure you update the QuickGPSfix data as often as possible and at least once a week.</description>
<image mimetype="image/png" url="http://home.tomtom.com/media/ephemeris/icon/ephemeris.png" usage="icon"/>
<download>
<url location="http://home.tomtom.com/download/Ephemeris.cab?type=ephemeris&amp;eeProvider=globalLocate&amp;devicecode=AKXS2CSDS6" content="main" size="61440"/>
</download>
<size>61440</size>
<targetdevice models="Siracusa_liveEU_4096 casablanca1024_gl casablanca512_gl cork0 cork1024 cork512 gg_1024 gh_1024_tts gi_2048 gj_2048_tts gk_2048_tts gl_2048_tts go540_1024_t_weu go740_2048_t_weu go750_1024_t_weu go750_1024_weu go750_2048_t_weu go750_2048_weu go750_4096_t_weu go750_4096_weu go750_blue_me_v1 go9000 go940_4096_t_weu go950_4096_t_weu go950_4096_weu gp_2048_tts limerick0 limerick1024 limerick1024_tts limerick512 one2008_s_1024_m one2008_s_1024_m_tts one2008_s_2048_m one2008_s_512_m one2008_t_512_m one2009_plus_1024 one2009_plus_1024_tts one2009_plus_2048 one2009_plus_2048_pearl one2009_plus_2048_pearl_tts one2009_plus_2048_tts one2009_plus_us_2048 rider3 xa_1024 xb_2048 xc_1024 xd_2048 xf_2048_tts xh_2048_tts xi_2048_tts_us xj_2048_tts_us xk_2048_plus_us xl2008_s_2048_m xl2008_s_2048_m_tts xl2008_t_1024_m xl2008_t_1024_m_b_tts xl2008_t_1024_m_tts xl2008_t_2048_m xl2008_t_2048_m_b xl2008_t_2048_m_tts xl2009_live_eu_2048 xl2009_live_eu_2048_tts xl2009_live_us_2048_tts xl2009_plus_1024 xl2009_plus_1024_tts xl2009_plus_2048 xl2009_plus_2048_tts xl_2048_plus_us xm_2048_plus xn_2048_plus xxl2009_2048_tts_grey xxl2009_plus_2048_black xxl2009_plus_2048_tts_black xxl2010_plus_4096_tts_black"/>
<price free="true"/>
<supplier id="tomtom">
<name>TomTom</name>
<image mimetype="image/png" url="http://home.tomtom.com/media/suppliers/tomtom_supplier_icon.png" usage="icon"/>
</supplier>
</ephemeris>
</HOME2>
in .\framework\InstallToDeviceThread.cpp:1423
Stack:
1. Connect to the computer. Make an Explorer, not Home backup of your unit's contents.
2. Start-->Run-->cmd and in the box that opens type chkdsk G: /f
3. Format the unit. Don't use quickformat.
4. Restore the backup.
Try the steps to get the new gps file now.
Re dhn's step #1....
You may find Windows won't copy the dodgy file either. If so, just make your backup by copying everything EXCLUDING the "ephem" folder. Then make a fresh empty folder with that name manually.
Thank you for the suggestions guys, I will copy and paste them should I get the problem again. I have been trying to update using my laptop running Win 7 64bit, whilst getting all these problems. Yesterday I tried to do the update using my desktop running Win XP and hey presto update completed. :) Maybe Win 7 had corrupted some files on my Tomtom One.
Regards.
Colin
ScouserJoe
