Go730 sleep mode and XL difference
<img src="/styles/default/custom/flags/nz.png" alt="New Zealand" /> New Zealand
go730, XL
After reading various forum posts about sleep mode, I've come to the conclusion that it's not possible to shut a TomTom down completely in an easy manner, and when I boot into the info screen it lists 'startup mode' as 'sleep'.
A couple of days ago I picked up an XL, and after sorting a few issues with some corrupt files I decided to look at its startup mode. It says 'power down'.
This leads me to thinking that it's possible to change this setting, but I don't see how.
Any thoughts?
As far as I know, the newer models DO have both 'sleep' and 'off' buttons. Older models such as the one you refer to do not. I believe the 'off' in those models is like turning a TV 'off' where, in fact, it is still drawing power.
But I could be wrong ........ :cool:
No, you have it right, dhn. Way back in the day, the devices went into a deep sleep mode where they were just barely running while they retained the most recent ephemeris data for a period of time. Then they would eventually shut down entirely to avoid running the battery down too low. Here's a link to my blast from the past! >>> https://www.tomtomforums.com/threads/my-330-xl-s.29717/#post-175713
BartG
